Ergon Clean® – Septic Tank Digestor & Failed STP/ETP Solution
Biotechnology, statutory compliance, and environmental responsibility,
Ergon CleanAdvanced Bio-Technological Solution for Septic Tanks, Failed STPs & ETPs
 Ergon Clean®  introduces enzyme-producing microorganisms into the wastewater ecosystem.
Regulatory Position on Ergon Clean®
  • Classified as non-hazardous
  • Free from toxic chemicals
  • Safe for human handling and municipal usage
  • Suitable for government, institutional, and private projects
Ergon Clean® Septic Tank Digestor is a next-generation bio-augmentation solution designed to rejuvenate and optimize septic tanks, failed STPs (Sewage Treatment Plants), and ETPs (Effluent Treatment Plants). It replaces conventional, high-maintenance septic systems with a self-sustaining biological treatment mechanism that accelerates organic waste degradation using a scientifically selected consortium of anaerobic and facultative bacteria. Unlike chemical additives or mechanical aeration systems, Ergon Clean works naturally, without electricity, and without producing sludge, aligning perfectly with India’s environmental regulations and green building standards
⚙️ Technology & Working Principle 🌿 Product Overview – Ergon Clean® Digestor
  • Anaerobic & facultative bacterial consortium
  • Digests fecal matter, grease, oils and organic solids
  • Reduces BOD, COD and sludge volume
  • No electricity or moving parts
📜 BIS / NBC / CPHEEO Compliance
Complies with IS 2470 (Part 1 & 2):1985 and NBC 2016 Part 9. Qualifies as an advanced on-site sanitation system as per CPHEEO guidelines.
🏢 IGBC Green Building Contribution
  • 💧 Water Efficiency – Treated wastewater reuse
  • 🌱 Sustainable Sites – No soil or groundwater pollution
  • 😌 Indoor Environment – Odour-free sanitation
  • 🚀 Innovation – Bio-digestor technology
🌎 Eco-Friendly & Green Benefits
  • ♻️ Zero chemicals & zero electricity
  • 🚫 No sludge overflow
  • 💧 Protects borewell & groundwater
  • 🌿 Reduces fresh water demand
📦 HSN Code
HSN Code: 3507
Category: Bio-based sanitation & wastewater treatment products
🧪 Dosage Instructions
  • Domestic Septic Tank: 25 g per 1000–1500 liters
  • Apartment / Commercial STP: As per tank volume
  • Initial dose followed by maintenance dosing
  • Do not mix with chemicals or disinfectants
🛡️ MSDS & Safety Declaration
Ergon Clean® Digestor is a non-toxic, eco-friendly microbial product. It is safe for humans, plumbing systems and the environment.
Manufactured and supplied by Ergon INC. MSDS available on request and compliant with environmental safety norms.
1. Product Identification
Product Name: Ergon Clean® Septic Tank Digestor
Product Type: Bio-based wastewater treatment digestor
Manufacturer: Ergon INC
Recommended Use: Septic tanks, failed STP & ETP biological restoration
2. Composition / Information on Ingredients
A proprietary blend of naturally occurring anaerobic and facultative bacteria with enzyme-producing bio-cultures.
  • Beneficial microbial consortium
  • Natural carrier media
  • No hazardous chemicals
3. Hazard Identification
This product does not present any significant hazard when used as intended.
  • Non-toxic and non-corrosive
  • No flammability risk
  • Mild irritation possible with direct eye or skin contact
4. First Aid Measures
  • Inhalation: Move to fresh air if discomfort occurs
  • Eye Contact: Rinse with clean water for 15 minutes
  • Skin Contact: Wash with soap and water
  • Ingestion: Rinse mouth; do not induce vomiting
5. Fire Fighting Measures
Product is non-flammable and non-explosive.
  • Suitable extinguishing media: Water spray
  • No special fire hazards identified
6. Accidental Release Measures
  • Avoid dust formation
  • Collect spilled material mechanically
  • Dispose according to local environmental regulations
7. Handling and Storage
  • Store in a cool, dry place
  • Protect from direct sunlight and moisture
  • Keep container tightly closed
  • Avoid mixing with disinfectants or chemicals
8. Exposure Controls / Personal Protection
  • Use gloves during handling
  • Wear safety goggles in dusty environments
  • No respiratory protection required under normal use
9. Physical and Chemical Properties
  • Appearance: Granular / powder form
  • Odour: Odourless
  • Solubility: Dispersible in water
  • pH: Mildly alkaline
10. Stability and Reactivity
  • Stable under normal conditions
  • Avoid excessive heat and moisture
  • No hazardous reactions known
11. Toxicological Information
Product is non-toxic. No known adverse health effects when used as directed.
12. Ecological Information
  • Eco-friendly and biodegradable
  • Does not bioaccumulate
  • Safe for wastewater ecosystems
13. Disposal Considerations
Dispose contents and container in accordance with local environmental regulations. Empty packaging may be recycled.
14. Transport Information
Not classified as dangerous goods under transport regulations.
15. Regulatory Information
Complies with applicable environmental and safety regulations in India.
16. Other Information
This MSDS is prepared for informational purposes and reflects best practices for safe handling of Ergon Clean® Digestor.
Overview – Failed STP & ETP Recovery
Ergon Clean® is a bio-augmentation solution designed to revive failed Sewage Treatment Plants (STPs) and Effluent Treatment Plants (ETPs) by restoring microbial activity without mechanical or civil upgrades. Common Reasons for STP & ETP Failure
  • Low or inactive MLSS
  • Shock chemical loads
  • Sludge bulking & foaming
  • High BOD / COD inflow
  • Odour and compliance issues
How Ergon Clean® Restores Biological Performance
Ergon Clean introduces beneficial bacteria and enzymes that re-establish biological balance, enhance organic degradation, and stabilize sludge characteristics in aeration and anaerobic zones.
BOD, COD & Sludge Reduction Benefits
The bacterial consortium accelerates breakdown of organic matter, reducing BOD and COD while controlling excess sludge generation and improving settling in secondary clarifiers.
Odour Control & Workplace Safety
Ergon Clean eliminates foul odors such as hydrogen sulphide (H₂S) by promoting controlled biological digestion, improving operator safety and surrounding environmental conditions.
Energy & Operational Cost Reduction
Improved biological efficiency reduces aeration demand, lowers electricity consumption, minimizes chemical dosing, and reduces overall operational expenditure (OPEX).
Regulatory & Green Compliance
Supports CPHEEO guidelines, Pollution Control Board norms, Swachh Bharat Mission objectives, and contributes to IGBC green building credits under Water Efficiency and Innovation.
📞 Call / WhatsApp: +91 93630 17774
🌿 Eco-Friendly | Zero Sludge | Green Building Ready
    • Ergon Bio Tank Profile
      The Ergon Bio Tank® by Ergon INC is India’s leading eco-friendly onsite wastewater treatment system, designed for homes, villas, apartments, commercial buildings, institutions, and light industries. Powered by advanced Bio-Nano Technology, it ...
    • Ergon Bio Tank -Work & Calculation - User & Standard - CPHEEO & MoHUA & BIS Data Sheet Technical Sheet
      Ergon Bio Evaporation Tank System – HSN 6810 Passive Secondary Treatment • Evapotranspiration • Zero Liquid Discharge 1️⃣ Product Overview Product Name: Ergon Bio Evaporation Tank System HSN Code: 6810 Manufacturer: Ergon INC Category: Passive ...
    • Ergon INC -About Us - Eco-Friendly Manufacturer & Digital Marketering
      🌐Ergon INC is built upon the Our philosophy: "Save Earth and the Future." Ergon INC. is a purpose-driven organization delivering integrated sustainability and digital growth solutions across engineering, infrastructure, and technology. The company’s ...
    • Ergon Bio Cleanser -HSN 3507 - Bio-Enzymatic formulation Anaerobic Bacterial Digestion
      ✔🔹 Stage I – Bio Anaerobic & Anaerobic Bacterial Digestion Ergon Bio Cleanser® is an advanced bio-enzymatic formulation developed for anaerobic and hybrid wastewater treatment systems. It accelerates natural digestion of organic waste, reduces ...
    • Ergon Digital Marketing - NEXT LEVEL
      Sustainable Since 2005 • “Save Earth and the Future” 🌿 Ergon INC – Eco-Friendly Manufacturing & Next-Level Digital Innovation Pioneering Sustainable Technology Since 2005. We unite green engineering and digital intelligence to build a cleaner, ...
